Temp Gauge
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jul 8, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    My temp gauge stopped working. What could be the problem? The sender?? Also, where does it take readings or where is it attached to the block? Thanks for your advice.
    YEEEEE HAWWWWW[​IMG]
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    OK Corby, I'll narrow it down to the gauge or the sender!! [​IMG] Your temp gauge gets it's signal from a sender in the head (I think). You might try lookin' for it on the drivers side of the engine, that's where mine is....I knocked the wire off while I was changing plugs once and my gauge quit. The sender is fairly cheap and just screws out. Ifyou replace it don't use teflon tape, they make a special "sender compatible" silicone that enables the sender to reference ground. What you'll see from the outside is just a little nut with a wire under it. I'm sure someone here knows exactly where it is.......now you question will be at the top again anyway. Let me know if this doesn't help.
    Michael [​IMG] http://jmartin.net/parker/goose.htm
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I believe you will find the temp sensor on the intake manifold....
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  4. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    The temp sensor for mine is on the driver side on the head I beleieve.. It's just look for the only plug with a wire going to it down there.. There is a temp sensor on the mainifold for the ECM which I do believe isn't connected to the guage.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  5. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    It is quite possible you are right, I was looking at the Chiltons manual and it did not differentiate between the two. I always remembered the temp sensor in the manifold....I must be getting old... [​IMG]
    2B1ASK1
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I looked and there is a wire coming from the #7 plug area, I followed it and it's not connected to anything. It was just laying on the frame. Could this be it? Also what/where does it plug in to?
  7. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    There should be a sensor on your driver's side head, right between the first two exhaust ports.
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    See in the attached picture where mine is located. I know that engine is messy but its a pic of when I was cleaning everything to repaint the block so my new headers wouldn't make the rest of the engine look so bad.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  9. Michael
    1,576
    Sherman, Texas
    OK, I went out and looked, mine is between 1 & 3 cylinders just like the previous picture. It doesn't have a nut holding the wire, just a little black clip that snaps onto the sensor. The wire then runs into the loom on top of the engine. Keep in mind, mine is a '74 so there may be some difference. You might also find a ceramic resistor on the back of the gauge that is loose or "open". I think this is in the range of 90 ohms. Some "real" auto supply shops used to carry these replacement resistors. Make sure your wire is connected then check the gauge.
  10. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    And again Michael you are right...twice in one day....
    Is this a record???? hehehehehehe gotcha...
    2B1ASK1
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks guys I got it working, I think I just knocked it off when I was replacing the plugs.
  12. Laurie
    Laurie Registered Member
    Jun 3, 2000
    44
    Oregon
    Blazer Guy:
    Making me dizzy at the sight of Texas [​IMG].
