TEMP GUAGES
Discussion in 'The Garage' started by jackedjimmy, Jul 24, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I plan on instaling a oil temp guage as well as a transmission temp guage in my GMC later on down the road.
    I don't really want to be drilling all kinds of holes in the tranny or oil pan because thats just another spot where it could leak from.
    Can't i just plug a sensor in the cooling lines right before they go into the cooler.
    As far as the oil goes, couldn't it go in either of the sensor spots on the engine(SBC) I won't have he idiot light anymore so that leaves a spot for the PSI guage and an empty spot where i should be able to put a sensor. Right??
    Any help appreciated
  2. jackedjimmy
    May 18, 2002
    195
    Redmond WA
  3. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    ttt again...don't mean to be an ass but i need some info.
    thanks
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The perferred place for a trans temp sensor is in the pan. But Yes you can plumb one in the cooling lines up stream fron the oil cooler. It will work fine.
    As for the engine oil. Just replace the stock oil pressure sending unit for the idiot light, with the sensor for the new oil guage . Most oil guages come with all the fittings you need.
  5. blazen_md
    blazen_md 1/2 ton status
    Aug 20, 2001
    129
    MD
    Would you want to plumb the transmission temp. guage in the return line or the line that feeds into the cooler??
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I personally want to know how HOT the tranny is getting so I'd go with the line going TO the cooler(temp of fluid BEFORE it's cooled).If the feed temp. is o.k. then the return line temp's will of course be cooler.
