Temp sender questions...which ones and where...?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Jul 30, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I was trying to figure out some wiring issuse today and was reminded of my non-opperational coolant temp gauge...I then recalled that some 350's have a sender at the neck at the thermostat and some have a sender in the head between cylinder #1 and #3...well I have a sender at the thermostat the has a couple wire coming out of it, and I have what looks like a sender in the head bewtween 1 and 3...the sender in the head has nothing hooked up to it and the part protruding form the head kind of looks like the head of a nail...is this then temp sender i need to hook my temp gauge up to? Thanks for the help gang...I really need to know how hot this thing is getting b/c last time I drove it was in the winter and I didn't own it last summer so I don't know what to expect from it...thanks again...
    Chris
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    On my 71 with mechanical guages the guage hooks up between 1 and 3. Therefore I believe that is the one you need to make the guage work.
  3. dyeager535
    26,982
    191
    Yep thats it. Crummy connector GM used for quite some time probably broke and melted on the exhaust /forums/images/icons/smile.gif
  4. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    the sending unit for the temp gage in the dash is the one in the head . it is suposed to loke like that(like a head of the nail) just hooked the therminal on it and BAMM it should work!!! (it hook up sideway not strait on)
    As far as the one in the termostat housing is for the ECM
    (kinda square looking connecter whit a few wire on it)
    u must have a EFI or a feed back carb ,that why it's there.
  5. dyeager535
    26,982
    191
    I would assume even the trucks with the mixture control governed by temp would have received the temp sender in the water neck as well... (I don't believe that is considered a Feedback Carb)
  6. tipoil
    Jul 30, 2002
    222
    canada guebec
    I think that ur right dyeager535 not sure(the emession law are diff.here (canada)).we had the ones whit the double acceleration pump controled by the temperature,for sure!
    anyway, i use the term"feed-back" for all the ones whit electronic stuff on it. It hard to keep track of all the weird name they (GM)come up whit.
