Temp Switch Part number for cooling fan
Discussion in 'The Garage' started by Mudzer, Jan 31, 2005.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Does anyone have a part number for any GM temp switch that would energize at 185°F +/- or so and de-energize at 165°F +/-?
    I do not want to pay Painless or any other place over $50 for a wiring harness for my Winstar fans. They just mark it up and do what I can already do!
    List a part number. I would consider any make as long as it did what I wanted.
  2. dyeager535
    26,982
    191
    I don't think you are going to find one from GM, and probably not from any maker. Those temps are much lower than any maker used AFAIK, the lowest you are going to find is around 195* and was used (at least) on the later Buick GN's, say 1987 or so.
    Can probably find that part number by vehicle at acdelco.com
  3. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Try your local parts store. They should be out in the aisle near there replacement electric fans. I got an automatic relay from there when I went to dual fans. I think I paid something like 30 bucks for the relay and the wiring setup. Also had a connection for a toggle switch in case it gets too hot for your comfort, you can just flip the switch and let it cool down.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's a company out there that sells different temp switches, but I can't remember their name! :blush: They used to be called Mid-America Corvette, but they changed their name. It looks like they let their ownership of the old name expire on the web and someone else has hijacked it. :(
    Does anyone remember their new name? I'm sure that I've seen the switches in their catalog.
