temperature fluctuation
Discussion in 'The Garage' started by dammit32, Feb 9, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    The temp guage on my ever-reliable K5 seems to fluctuate alot. During warm-up from a cold start(usually 20F or below) it doesnt stop at 200 like it used to ...it has been climbing to 240 or so before dropping back down to 200 but then it doesnt always stay at 200 ?
    I'm guessing I have an old and maybe tired thermostat but I am all ears to any other suggestions /forums/images/graemlins/smile.gif
    I checked the fluid levels and conditions and all is fine.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It sure does sound like a sticky thermostat. $10 and 20 minutes work will let you know for sure. Your thermostat should be changed out every so often anyway, so it's not like you'd be wasting money.....
    I'd be curious to see if it persists after you swap in the new part. It could also be a faulty sender or gauge, but do the easy fix first. /forums/images/graemlins/thumb.gif
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Make sure you don't have a giant air pocket in the top hose. Mine always do that a few times when I first fill it up with water.
