temperature gauge not working
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Oct 4, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Just looked at the temp gauge today after driving for a while and it was way below 100...and the engien is fine. What could be wrong with it?
    90K5
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Probably a screwed up sender - cost around 8 bucks for a new one.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Not to insult your intelligence or anything....but make sure the wire didnt just slip off the sensor, and that it is good from the sensor up to the guage. Also, those sensors can go bad and they are cheap and easy to replace.
    Hope this helps.
  4. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    Mine works fine, the temp is always smack in the middle of the guage, even before I put the key in the ignition.
    $8 will solve my problem.
    <font color=red>I will not tolerate intolerance </font color=red>[​IMG]
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i second 4x4 blazer i knocked mine off once while changing spark plugs. it should be on the drivers side around the center of the block. hope this helps
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Oh yeah...green wire near spark plugs?...disconnected it working on valve cover gaskets last weekend...sad thing is it took me this long to notice.
    90K5
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's the one! Drivers side of the engine. [​IMG]
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    It probably is the sender but you can test your gauge by grounding your sender wire. Just unhook it and touch it against your manifold (cold, of course) and check your gauge. It should go allll the way over to the right if it its OK.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  9. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK since his problem is now solved, Ihave one myself. My gauge just trips out. At times it will be dead and others it whips all over. Seems like now its just dead towards the top. I just got the rig up and running so I put in a new sender a few weeks ago. When I ground out the wire it does nothing. Is it the gauge itself thats messed up or do I have another problem?? I will be installing manual gauges( no sending units to worry w/ ) But I would like to have this one running also. (just until I tear it all out and go w/ all Autometer gauges)
    If ya can't stop.......Smile as you go under! [​IMG]
  10. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Could be your gauge or have a short/bad connection.
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds like your gauge itself has gone tits up - I think Ben (Itali83) has one he'll part with. Shoot him a PM and check it out[​IMG]
  12. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Thanx guys! Ill look for a bad connection, but Im putting in a set of mech. gauges, so I wont put a whole bunch of time into it. I was hoping this was a common and easy fix. Which it is, but Im not gonna bother to replace the fact. gauge, just to tear it out anyhow.
