Temperature sensor/gauge problem...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 21, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I just relplaced my temperature sending unit and it's a no go...still no temperature reading...Is there a way I can test the gauge I have before I drop $$$ on a new gauge... What other things may I have to trouble shoot to try to figure this out? thanks
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  2. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    If you take the wire of the sending unit, and ground it out, the guage should max out I believe, if it dosen't the guage is bad. Check with others but I think this is right.
    Ben 87 jimmy
    <font color=blue>Rust=Bad</font color=blue>
    <a target="_blank" href=http://www.bens87toy.alloffroad.com>www.bens87toy.alloffroad.com</a>
  3. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    That is correct. Just ground the wiring harness that connects to the temp sensor and the guage will go to max if it is working correctly. Really have to get a good ground connection to make sure the guage will max out. So, if it doesn't do it the first time, make sure you try it a couple of times. If it still doesn't work, you might want to trace the wiring for cuts, etc before getting a new guage.
  4. Slayer
    Slayer 1/2 ton status
    Oct 17, 2001
    225
    Eastern Colorado, jokingly referred to as Western
    <font color=red>I had the SAME problem................
    My crate motor came with a temp sending unit that did NOT work with the '77 OEM guage.
    </font color=red><font color=green>
    The guy @ Checker told me that in '89 the sensors changed resistance. My original sensor was the "large" diameter sender, but the crate motor took the "small" diameter sender.
    What he told me was to buy a "small" diameter unit for a pre-89 and I did.
    Installed it and it works just fine...............
    </font color=green>
    <font color=blue>I don't know everything, I just think that I do.............</font color=blue>[​IMG]
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I had the same problem as described below. I went to Northern Auto Parts (down the street from me) along with my ohm meter. I had them line everything GM up for me and went down the line until I found a match for the correct reading. They had a temp sensor by Standard, the number on the box is TS71. It pays to never throw things out, haha.
    <a target="_blank" href=http://www.geocities.com/bigkern76>The Blazer Boy Page</a>
