Temporary Front Driveshaft Removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigTex, Jun 22, 2003.
  1. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I'm putting in the 14Bff this week and its geared with 4.10s. I'm going to run the hogher-geared 6 lug front for a while until I buy the 4.56s for both diffs. What is the correct process in disconnecting the front driveshaft to drive around without it until I make the upgrade? Thanks in advance for all your help...
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    just unbolt it from the yoke on the rear and the yoke on the transfer case. it is a fixed yoke so you wont have to worry about spilling anything. or you could just keep the hubs unlocked and dont use 4wheel until you climb under to do the gears. I like your taste in trucks by the way. /forums/images/graemlins/thumb.gif
  3. BigTex
    Dec 27, 2000
    974
    South Texas
    Thanks, Ken! So if I'm understanding you correctly, as long as I don't put in in 4 wheel drive and don't lock the hubs, should I even worry about disconnecting the driveshaft with 2 different ger rations in the diffs? /forums/images/graemlins/ears.gif Thanks again, dood!
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    That sounds correct to me.
  5. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    you can use one or the other, not both. like if you wanted low range for pulling something, leave the hubs unlocked and put it into 4low. it would be like have 2low since your hubs wont be locked. just dont lock the hubs and have it in 4 wheel at the same time. /forums/images/graemlins/thumb.gif
  6. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Just wanted to add a confirmation... so far these guys are right on correct!
    Ken H.
