terribly frustraited
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Jun 22, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    got a steering wheel puller and something called a lock plate remover...
    the lock plate remover is broke, and the steering wheel puller bolts wont fit in the holes they are supposed to
    no...rather one of them will and the other one wont.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    loosen the bolts that hold the steering wheel down, and beat around the rim of the wheel with your hands til they get red, should come loose...
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    [/ QUOTE ] Atleast your not pissed anymore..... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Dude, the steering wheel puller should be a breeze to use. You shouldn't have to do any banging or anything. It should have all different sizes of bolts for your application. If you rented it from an auto parts store, some may be missing. You may be better off just buying one that Grant makes. It should have all of them. By the way, you don't have to remove the lock-plate if you are just changing your wheel. Hope this helps.
  6. BigTex
    Dec 27, 2000
    974
    South Texas
    Oh, and you should be using 3 bolts at the holes where the original screws for the horn go. And one larger bolt in the center of the puller. This is the one you tighten to break the sterring wheel loose.
  7. tecton
    Dec 1, 2002
    1,553
    WV
    lol
    long story short...i broke 2 pullers, and we wound up pulling the wheel while a guy used a sledge on the center and it popped right off...
  8. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    Sounds painful
  9. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I've done the hammer trick. Works ok.
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    lol
    Like 2 of us suggested in your other post /forums/images/graemlins/thumb.gif
