tesst
Discussion in 'The Test Lab' started by 73k10sub, Feb 28, 2006.
  1. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    I have two Sub projects that I am not going to be able to do.
    The '73 is a rolling chassis: D44 and a twelve bolt. The BOM on the 12 bolt is TAJ, which, per a Hollander's book at a local salvage yard, is 3.07:1 w/locker. Some previous threads on this site say this is the rebuildable Eaton vs. the gov-bomb. I have no clue and no immediate way of finding out. In addition to the chassis, I also have the 30 gal. gas tank, mounting straps, and filler neck, the transmission hump (this was a bolt in item on this model), the rear light harness, and the harness from the firewall forward. The Sub was rolled before I bought it but I was able to drive it on a trailer. The body, engine, transmission, and transfer case are gone. I have no pics of the gas tank, etc. It is currently stored in West Texas near San Angelo. I could deliver it along a route from there through Wichita Falls or Dallas/Ft. Worth to Tulsa. $275.00 with a title, $200.00 without and we could work something out on gas. Pics at : http://coloradok5.com/photos/showgallery.php/cat/681
    The ’88 is a former Air Force vehicle: ¾ ton, 8,600 lb. GVW, 9 passenger, Scottsdale, 3.73 gears, 5.7 EFI, TH400, and 208 t-case. It also has intermittent wipers, 105 amp alternator, and front/rear air (does not work). You can PM me for a list of the RPO codes. Except for some surface rust on the body, this vehicle is about as rust free as you will see for an ’88. It has part of an AZ emissions inspection sticker on the right rear passenger door. I bought it at Tinker AFB in OK City. I believe it has never been driven is a salted road situation. Pics will show some dents in the body. The paint is fair and needs to be polished. I believe a couple of the doors were repainted as the blues a little different. The interior is fair with no major rips in the seats. They repaired some with those glue kits from the auto parts stores. The rubber flooring is pretty rough with several cracks and a hole where many driver’s feet have been. Tires are Firestone LT245/75R16 that are fair and the spare is a LT235/85R16.
    It would make a good hunting/fishing/camping rig or it would be the base for a build up. It runs good. I used it a bit to move household items last summer but have not driven it enough to get a feel for fuel mileage or oil usage. It puffs a little bit upon start up but is not a mosquito killing fog that some of these engines will do with age. This vehicle was on CNG at one time. The CNG tank was missing when I got it and I have since removed everything else (the under hood/electrical stuff). It has 95,069 miles on the odometer.
    Things I know it needs: a radio and speakers (came without), the A/C repaired (it is unplugged under the hood and the rear unit blower motor is bad), drag link and tie rod ends, shocks, and a steering stabilizer. And as much TLC/dollars as a person would want to put towards the interior. Delivery might be a possibility depending on distance from the Tulsa, OK area. . Asking $2500.00. ’88 pics at: http://coloradok5.com/photos/misc.php?action=orderphotos&s=&cat=682
  2. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    hmmm,:confused:
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    too long for me to read.....you in the right forum
