Test Your Gm Mechanical Knowledge
Discussion in 'The Lounge' started by Resurrection_Joe, Jan 15, 2005.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Or, help me do my job
    I need a list of all the common GM trannys
    NO not transvestites
    Links to info would help too
    I will return favours
  2. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    we are talkin truck type right? you have the th200, (or th250 ??) th350, th400, th700r4, newer ones would be the 46l0e and 48l0e and the alison in the hd. manual. older one may see an sm 420 4 speed. 73-87 would be a sm465 4 speed. then you got a 5 speed but I dont know model.
  3. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    nv 3550,nv4500, Muncie 3speed manual, also a saqinaw 3 speed manual, and sm435
  4. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    nv5600 6 speed
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Just trucks sorry
    Thanks guys
    Post up names if you want source credit
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    my names in my sig ;)
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    TH200-R4 was a car transmission not truck.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    autos: th350, th350c, th400, 700r4, 4L60, 4L60E, 4L65E, 4L80E
    manuals: sm420, sm465, nv3500, nv4500, saginaw 3 speed, T5 (if you want to include the s10)
  9. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    My 70 owners manual also lists a Warner 3 speed, but no model #.
  10. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Dont forget the ZF 6 speed behind the Duramax and the 8.1L.
  11. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    well... I have actually seen a smaller than th350 in an 84 4x4 short bed before. So it all depends on how you look at it cuz a th350 and th400 th700 are also car trannies... :dunno:
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    For manuals, there was also a 4 speed manual that was an overdrive tranny. Can't recall it's 'name'
    For whoever mentioned the NV5600, GM has not used that 6 speed yet and probably won't. The 6 speed available in the newer GM's is the ZF6-S-650.
    So far Dodge is the only one using the NV5600.
    For 5 speeds there was the NV4500.
    From the spec's page we have this:
    SM318/SM326/SM330/T-89A/T-150 3 spd. (2.47-3.50:1 First Gear)
    SM465 4 spd. (6.55:1 First Gear)
    Rene
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    TH200R4 is about the samesize as the TH350, also the 200R4 has an integrated tailhousing that can't be removed and replaced with an adapter. So basically you couldn't have seen a 200R4 in there unless it was really custom.
  14. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :dunno: whatever it was it was not as big as the th350 and was not nearly as strong as the tranny guy refused to rebuild it.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    what kind of trans guy would refuse to rebuild any transmission? Not to mention any trans guy worth his salt knows a 200R4 is weak stock but can be built up pretty good.
  16. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Dunno if it's been mentioned, but the T-56 6 speed, I thnk you can get it in the brand new trucks
  17. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Dont forget about the 4L85-E behind the 8.1 in suburbans and avalanches.
  18. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    That would be the A-833. Small aluminum housing about the size of a saginaw 3 spd. Found in some mid 80's GM 2wd trucks. I'd love to find one of these for cheap to put behind a 6.2L in a '73 C10 I'm getting soon. Should make for a great MPG daily driver.
    As far as the 200R4 being used in a truck, it was probably swapped in if you ever find one in there. They were only in cars from the factory. Trucks were only using Hydromatic, Powerglide(Chevy)/PowerFlo (GMC), TH350, TH400, 700R4, and 4L80E's in 1960-87(91) 1/2-1 ton trucks depending on what year your talking about.
    Manuals were the SM-420, NP-435, SM-465, A-833, Getchrag 5 spd, NV-4500 in 4 and 5 spd's. I don't know all the models for 3 spd's though. This should cover 1948-mid 90's 1/2-1 ton models.
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    who can forget the TH-350C?:D
  20. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    there is the TH450 motorhome trans
