TEST YOUR MECHANIC SKILL
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by purple89jimmy, Mar 3, 2002.
  1. purple89jimmy
    purple89jimmy Registered Member
    May 29, 2001
    75
    I'll try to keep this short. I lost power steering that would intermittently return at higher RPM. First I bought a new PS pump, didn't work. Then I rebuilt steering box, didn't work. Then bought new steering box, still doesn't work. Disconnected steering shaft, spins easy. Jacked up the wheels and disconnected drag link, ab;le to turn by hand with ease (ie no binding anywhere) Only thing I can think of is that I was sold a bad pump. What are your opinions/suggestions? Thanks.
  2. 1BAD88
    1BAD88 Registered Member
    Feb 23, 2002
    89
    bristol ct
    Re: OPINIONS ON VEXING STEERING PROB
    One of my buddys had a problem like that a few years back it turned out to be a siezed ball joint .it broke inside the knuckle and he almost could'nt turn the steering .Maybe try to pop off the steering bar and you should be able to turn the hub assembly with ease try it on both sides and for the drivers side pop off the drag link and see if it the hub moves freely If this is not the problem then check all your steering tie rods for wear and cracks and hopefully this will help you find the problem...good luck.....
  3. purple89jimmy
    May 29, 2001
    75
    Tried all that. Like I said, I removed the drag link from the steering arm and jacked the front of the truck up. Once it was jacked up I could turn the wheels from side to side with ease. Anyone else got ideas? I think it is the steering pump, but I just wanted confirmation from someone else who knows what they are talking about before I pull that pump once again (it is a PITA to remove that pulley without the proper tool!). Thanks for the reply 1BAD88, I can't believe I still have this prob after new tie rods, ball-joints, draglink, steering arm, box, and pump!
  4. Grim-Reaper
    7,385
    Atlanta
    Was the pump the style where you reuse your old resivior? did it come iwth a new fitting on the back of the pump that the pressure line connects to? That peice regulates the amount of pressure the pump sends to the box. If you reused it that's your problem.
  5. purple89jimmy
    May 29, 2001
    75
    I did reuse the reservoir, but it came with a new pressure valve. Is there a way to test the pump?
  6. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Is your belt slipping?
  7. 1BAD88
    Feb 23, 2002
    89
    bristol ct
    Just a thought .Check the metal lines that go from the pump to the box for kinks .If you did'nt use new lines they could be clogged...........
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Is your belt in good shape,not glazed or anything.
  9. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    Did you bleed the air out of the system real good?
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I would make sure that ALL the oil and grease is off the pulley then throw a new belt on...a belt CAN slip with out making any noise...just a thought...I also agree with the statements about the hoses...give them a good inspection...maybe one is kinking up when HOT? just a thought again...
    Chris
  11. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Ok, I know this is out there but maybe...
    Try looking at the axle joints. I've seen axle joints that (when bad) will be locked up on one side of the trunion(sp?) and free on the opposite side. Because they can rotate while driving you might be feeling the bad side occaisionally, this might explain why sometimes it's better than others. Just a thought.
    Even if you tear it apart and that's not the problem, it can't hurt to do a little maintenance and also give an opportunity to closer inspect the ball joints and such.
  12. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    could be the new defective pump. i had a similar experience. I put all the steering stuff in new from box to hoses to pump. had to rev it to make it "catch". called the guy who rebuilt the box and asked me if it was only hard to turn in one direction or both. if it was only in one direction it was the box, both dirrections it was the pump. pump that i had gotten new was bad.
    try it
    ARQ.
  13. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    when you installed pump pressure valve are you sure you removed little plastic plug that they cram in there to keep dirt out
  14. 85GMCJimmy
    85GMCJimmy Registered Member
    Feb 21, 2000
    83
    South Carolina
    I had the same problem as you, my problem was that the drive pulley was not pressed on tight enough. Mine would barely steer at low rpms but once you get them up, it would be fine. Thats just an idea, i know it sounds to simple to, but its a possibility,
  15. purple89jimmy
    May 29, 2001
    75
    WOW, thanks for the replies. I put new hoses on, but the belt does need replacing. I also thought about the pulley, but the pulley bottomed out when I put it on, so I know it is on all the way. Plus it gave the pulley installer a workout so i know it is on tight too. I think I will change the belt and if that doesn't fix anything I will go ahead and replace the pump with another new one. Is there a way to test the output pressure of a PS pump? Wouldn't that just be hilarious if I spent over $300.00 for a problem that could have been fixed with a $10.00 belt?!! You gotta love learning things the hard way!
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Heck, I'd so something simple first like disconnect one of the PS hoses and check to see if anything is even flowing!
    I dunno what the CFM is supposed to be, but I figure it cant be that low, its gotta generate enough pressure. If you can block it with your finger, I'd probably say there's something wrong with your pump. /forums/images/icons/smile.gif
    Another idea is to disconnect the output hose from the gearbox first... see if the fluid is gushing out. I would almost care to venture that perhaps something is stopping the fluid? (Maybe a kinked hose, etc?) Just a thought.
  17. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    make sure you bleed it correctly, you have to manually spin the pully the oposite direction as the motor turns it untill the level does not go down any more. that is how it is done on my 80 GMC. slow down throwing parts at it, it gets expensive.
  18. purple89jimmy
    May 29, 2001
    75
    Well, as I suspected Autozone sold me a bad PS pump. I got another one from them, bled it, and it works perfect. Just to clarify though, I don't "throw parts at it" trying to find out what was wrong. Everything I bought was needed. The ball joints were adjsted out and worn, the rod ends looked like they had never felt grease before and the pressure cylinder of the steering box had a badly grooved section of cylinder wall from the teflon rings getting too hot and expanding. So now I have a completely new front end. I still have a little bit of play, but I suspect that is from the steering shaft slip joint. Anyone ever change this out?
