Testin Articulation....?
Discussion in 'The Garage' started by RustBuket, Apr 23, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Ok, so now that I've borrowed an engine hoist and everything to redo my engine I remembered seeing a pic of an engine hoist hooked to a rear axle to test flex. I was just wondering if I could do this to my stock blazer or if I'd break it cause its not mine! /forums/images/graemlins/peace.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i bent the legs on mine picking up my s10. it had the motor (2.5L) sitting in the back thought.
  3. RustBuket
    Feb 21, 2003
    1,618
    What if I set it to two tons? What is that like 4000 lbs? It couldn't be that much on one corner? 5000lbs/4 = 1250lbs plus or minus however much because of not even weight transfer but I imagine the front would be heavier anyways.... /forums/images/graemlins/confused.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the ram was fine, but the legs is what was bent.
    2 tons is 4000 lbs
  5. RustBuket
    Feb 21, 2003
    1,618
    One would think that they would rate it to the machine's total capacity not the ram's capacity...... because I know those rams can lift a hell of alot on their own.
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I used my 2 ton set in the 1.5 ton position to lift my truck, and my truck weighs in over 8k pounds...
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have that same cherry picker and my legs are bent right at the second pin. the legs are 2.75 16guage. maybe yours are thicker. /forums/images/graemlins/dunno.gif
  8. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Willy-san, how did you hook the cherry picker to the axle? Looks like chain is attached to the outside of the tire... you didn't hork onto a lug nut did you?
    -- A
  9. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    If you look close at the pic you can see the chain looped around the tire /forums/images/graemlins/peace.gif
  10. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Lol, yeah I lifted it all up off one lug nut /forums/images/graemlins/yikes.gif
    No, I ran a chain around the top of the axle tube then down under the tire up to the cherry picker hook.
    The legs on my picker are at least 3/16-1/4"...
  11. dremu
    Feb 27, 2000
    15,958
    452
    Whew. I guess I need new glasses /forums/images/graemlins/eek.gif
    -- A
