Testing a TBI injector
Discussion in 'The Garage' started by 6.2puller, Jan 19, 2006.
  1. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    how would you go abouts testing a TBI injector to make sure it is good?
    I got a TBI motor in my brothers buggy that has fuel at the back of the throtle body and at the regulator but nothing sprays. Their is 12 volts at both of the inner injector wires, as in one side of each injector when the ignition is on but we are not getting fuel out the injectors. The motor ran fine until it sat for a month or two and now it will only run on either but will not spray fuel to run on its on.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The ECM grounds the injector to make it fire. Have you checked the fuses.
    Try cleaning the plugs at the distributor and coil. if the ECM sees no spark it will not fire the injector.
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Pull the connector from the pick up coil off of the ignition module, then use a noid light connected to the battery on the clip end......then alterneta touching the leads on the ignition module with the noid light.
    Every time you hit a lead on the module it will fire the hall effect device in the module and the ECM will fire an injector. If it does not it could be any of the following
    1. Module
    2. Computer
    3. Wiring
    4. Injector
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i had a problem after installed the motor for the 3rd time, it tured out to be we forgot to put the bolt in the back side of the head that grounds the harness, put that on and we had fuel.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sure there is fuel pressure? No fuel no spray
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The fuel issue is what I am currently chasing on my newly-converted to TBI, 350. I can only start if I give a little gas in the TBI, but it seems to run perfectly after started. While cranking it does not spray any fuel.
    So far I've swapped the MAP with a couple of spares, and rebuilt the TBI/fuel regulator, but still the same problem. Tonight, I'll drop the tank and replace the pump.
  7. 6.2puller
    Jul 8, 2004
    569
    New England
    I have been searching around and someone else had your problem. It turned out to be that the ECU was dropping down to 7V under cranking then jumped up to 9.6V once running. 7V was apparantly not enough for it to run.
  8. 6.2puller
    Jul 8, 2004
    569
    New England
    We Pulled the line at the back of the TB and it had fuel, then we pulled the injector risser and cranked it and the regulator "bowl" filled right up fast. Not sure how you can check pressure on these other than that since their is no Schrader valve like the other injected models.
  9. 6.2puller
    Jul 8, 2004
    569
    New England
    Will try this this weekend, thanks.
  10. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Mine are just dumping fuel into the manifold... this was after I forgot to hook my ground to the frame and fried my ecm hooking up my battery. Thing is I think they might have blown from too much fuel pressure before I fried the ecm. Is there anyway to check?(I have a new ecm now)
    *hijack over*
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that the ECM power is connected to the proper place. There's one feed that must have 12 volts at ALL times. Another must have 12 volts in RUN and in START. Most power feeds in the truck switch OFF in the START mode. If you have your ECM wired to one of those, the ECM won't work until you let the switch come back to RUN. :rolleyes:
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    6.2Puller - Do you have a spare ignition module that you can swap in? If the module isn't sending ignition reference pusles to the ECM, then the ECM won't fire the injectors.
  13. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Good idea, I'll double check, but I installed a second fuse block just to run the FI. Still, I gotta check.
