Testing an 8274 winch
Discussion in 'The Garage' started by POWERMAD, Apr 26, 2005.
  1. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I have one that came with the 69 and the guy said it stopped working, someone has been foolin with it, solinoids removed and such.
    When I grouned the case and put power to the arm. terminal it started winding up, what do I need to do to see if it spools out?
    It seems to be ok other than needing new solinoids and rewired.
  2. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the solenoid wiring is far from what i can state is common sense... use a manual.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    You have to have 4 solenoids for POWER out.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Poke around BillaVista's tech stuff over on Pirate4x4.com He did a VERY extensive teardown and rebuild of an 8274. Should be some good info there. :cool1:
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    there are 4 there but it looks like it had 2 more as well :confused:
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Ron, look here:
    The brown, green and light blue are coming from the backside of the remote plug. There should also be a ground wire coming off the bottom side of the control pack base to the threaded hole on the bottom side of the motor. If you do not have a remote, rig up a test remote using some lengths of wire and a ON/OFF/ON toggle switch. If you need any other info, call my cell anytime after 5:30pm, if you don't have it, you can get it from shannon.
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I used dead soft copper tube, beat flat, for the bussbars on the DB's winch relays.
    Could be the extra pair of relays were used to drive the winch relay pairs. I did this on the DB wiring b/c the self-coiling cord I used had really small wires. Smaller than I felt I could run event relay activation current thru.
