Testing an alternators amp output
Discussion in 'The Garage' started by opfor2, Jan 1, 2007.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hoe do I test an alternator to see how many amps it's producing? I have a supposed 200 amp alternator and I'ed like to see if it really can produce 200 amps.
    Dan..
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    You would have to use an ampmeter. Go to autozone, oreilly's, etc. , they have the capability of testing volts and amps.
  3. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    for FREE!!!! :D
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you want to see if it will really make 200 amps? at the point that it does make 200 amps, i predict a meltdown. so long as it runs everything you need it to run, leave it alone.
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    All the bench testers I have seen turn the alternator at a slower speed, so the current output is roughly about 15 amps IIRC. They just test to see if it is within a certain range, they dont test the max output.
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Bench tester is for testing just the alternator, The tester they have for amp testing is a portable that test the entire system on the vehicle. It will tell you pretty close to what the potential of the alternator is.
  7. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Full power??..
    You'd have to have it in a vehicle,with all lights on,(on high beams),all acessories on,and a carbon pile rheostat hooked across both battery terminals to create a "full load" situation,to see what the maximum output is..
    Of course you'll need an ampmeter, installed betwen the output wire of the alternator ,and the post it was bolted to,to read the output..
    You have to adjust the carbon pile rheostat while its running to load the system down enough to get an accurate reading..few if any places probably have a carbon pile rheostat,or even know what one is anymore--maybe a starter/alternator shop may still have one--they might have newer test benches that can read "full output" now..most GM alternators only reach about 80-90% of their rated output when installed in a vehicle,I guess its a safety factor, so it wont burn itself up...:crazy:
