testing my junk
Discussion in 'The Garage' started by bajaviking, Feb 15, 2007.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A couple of pics from last Saturday, just testing my junk after clocking the transfer, putting in the gears and bobbing the rear.
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    What did you use for your drag link? Looks like the tie rod. Did you cut and tap or...?
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    Yes, it was cut and a local machine shop did the threads on it.
  4. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    Nice body work!:rotfl: Question on your clocked 208, did you have to modify youre front cv (grind the ears a bit:grind: ) to keep it from rubbing cuz of too much angle?
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    Thank you for the compliment on the bodywork, I did it all by myself:D I haven't done any change to my front driveshaft except adding a 2.5 inches to the lenght.
  6. Irish Wake
    Irish Wake Registered Member
    Jan 15, 2007
    44
    Georgia
    I'm planning on testing my junk later on tonight after the kid's go to sleep:laugh:
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Thats kinda where my mind went at first also!:laugh: But aside from that ya man it looks like a fun truck!:thumb:
  8. bajaviking
    Apr 10, 2002
    752
    Baja
    Yeah I was refeferring to the truck, I wouldn't dare calling any part on my girlfriend junk, that would put a stop to any kind of testing right away:D
  9. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    How much did it cost altogether for the x over i wanna do this soon?
  10. bajaviking
    Apr 10, 2002
    752
    Baja
    Sorry I can't tell you exactly how much but it is a junk yard special that my buddy put together for me, he has a 4x4 shop and I had gotton tired of a Heep project which I gave him in return of him doing crossover, repairing my transfer and clocking it, installing my gears and fixing my brakes. I only had about $1000 in the Heep project, my buddy is happy with the Heep and I'm happy I got rid of it and my new mods turned out pretty good so it's all good.
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    that looks great!!!and bobed isn't the word for it.with the custom sheet metal it looks like a samy.!!!!!
  12. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    I am in the middle of mine. The cost depends on what you do. I decided that I am stopping at a 10 bolt front and threw some $$ at it. I am not going to run anything bigger than 35's or 37's. That will be a year or two before I do that. I think this was about the prices I paid plus or minus a little:
    Flat tops $50 - $70 for a set at local yard - I bought them last year - don't remember how much I paid for the set.
    Mill/Drill - $65.00 passenger side
    Pitman arm - $75.00 new (cheap Ford van arm at local yard $10 to $20)
    2wd box - $27.00 ( I swapped the sector shaft - didn't have to worry about which box to buy)
    Bent drag link - $85.00
    I also replaced all the ball joints and TRE's since I was going through the front end while it was apart. I also put in a set of Chome moly shafts.
    YJ/Cherokee steering shaft - $14.00 and the adapter u joint end since I am not switching boxes ($50.00)
    I didn't add it up and don't want to. I can honestly tell my wife "Not that much" if I have no idea how much I really spent.:haha:
    EDIT: Talk to Trevor - WFO Concepts or Morris at Parts Mike
    Morris did all the machining and ball joints. I bought the bent drag link from WFO just because he had one ready to go. Both great to deal with and I highly recommend either one.
