TH 350 and TH 400 Question
Discussion in 'The Garage' started by stano, Oct 9, 2005.
  1. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    Is a long tail Turbo 350 from 76 truck C20 (two wheel drive), The same length as a TH 400 short tail (two wheel drive)?
    Can we just change yokes and the trans?
    thank you
    stano 87 K5
  2. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    Dont think so....
    I'm not sure,but I think the TH400 isnt the same as ANY TH350,no matter what length "tail",but they might be close..(*most*not all, Gm trucks use the 9" tail TH350,the "medium" length tail")--.you'll have to move the crossmember to line up with the TH400's tail mount no matter what,(they are in a different spot--and you may have to drill the holes for the crossmember in the frame)..- you could use "conversion" U-joints IF the old driveshaft will be the right length..TH400's use bigger U-joints,so the driveshaft itself is bigger to accomadate the bigger u-joint caps..some trucks used two peice driveshafts and a center support bearing with TH400's.. :doah:
    I usually just get all the related parts at the junkyard off another truck that had a factory TH400 in it...its a hell of a lot easier..I realize you probably want to swap in what you have lying around (and who doesn't! :rolleyes: )--but its not always that easy...its usually bad enough just putting back what was there already!..
    A TH400 is a beefier tranny and more desireable,but its a lot of work to swap one in unless you have a "donor" truck with everything you need,like the kickdown switch,wiring harness,driveshaft,etc..A TH350 isn't junk,they hold up pretty good if you run a good size tranny cooler.. :crazy:
  3. stano
    Jan 24, 2005
    130
    Iowa
    thanks diesel 4 me
    stano 87 K5
