th 350 automatiC transmission
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kristoffer, Jun 5, 2001.
  1. kristoffer
    kristoffer Registered Member
    May 21, 2001
    32
    Norway
    hi, i have a 77 blazer k5 with a th 350. but it will not hold the 3 gear. it drops down, it helps if i put it in N and then down to D then it wil go in 3 for a little wile, but sudenly it drops down.
    Anybody have any ideas??? please help
    Sorry for my bad english.......
    Kristoffer
    1977 blazer k5 cheyene
  2. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Sounds like a problem with the vacuum modulator or the vacuum line leading to it... The modulator can be adjusted, but is cheep enough to just replace if suspect.
  3. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I'd guess that the line leading to the modulator is at fault or the TV cable is misadjusted. Either could cause a premature downshift.
  4. 2quicK5
    2quicK5 Registered Member
    Apr 18, 2001
    46
    TN
    It's probably just a vacuum modulator gone bad. Check to make sure that the vacuum line going to it is connected and that the modulator will hold vacuum. If the modulator is OK then the tranny cannot hold line pressure which would require a tranny rebuild to fix. To the best of my knowledge TH 350s have a vacuum modulator and passing kickdown cable, not a TV cable like a 200R4 has which takes the place of a vacuum modulator.
    John
    1972 K5 Blazer: 400 ci, 4 sp, 4" springs, 35" Tires
    2000 Trans Am, A4
    11.97@114 mph
  5. kristoffer
    May 21, 2001
    32
    Norway
    how do i adjust the modulator??
    Kristoffer
  6. 2quicK5
    Apr 18, 2001
    46
    TN
    Some modulators have a set screw that can be adjusted with a small flat blade screwdriver through the vacuum port on the modulator after the hose is removed. Turning the screw clockwise causes the trans to shift later and harder, turning the screw counterclockwise causes the tranny to shift sooner and softer. Check to make sure your modulator can hold vacuum first though. You can use a short piece of rubber hose and suck on it to see if it will hold a vacuum.
    John
    2000 Trans Am, A4
    11.97@114 mph
