th 350 question
Discussion in 'The Garage' started by dheavychevy38, Mar 12, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ok i swapped a th350 in place of a 700r4 in a 89 k5 with a tbi need a adapter or idea on how to hook up the th350 detent cable
    cause the difference is the hook up connection and i need throttle cable braket with a th350 hook up /forums/images/graemlins/confused.gif
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I think the TH350 Detent pin is a common piece that can be purchased through Jegs or Summit for aftermarket carbs but you should be able to unscrew the TV pin and replace it with a Detent pin.
    I did the same swap and used a manual valve body so I didnt have to worry about the vacuum advance/detent/governor. But it was, ofcourse, more expensive than buying a little pin.
