TH 350 to TH 700
Discussion in 'The Garage' started by Anthonviking, Jun 30, 2003.
  1. Anthonviking
    Anthonviking Registered Member
    May 25, 2003
    44
    Varnamo, SWEDEN
    Planing to swap my TH 350 / NP 203 to TH 700 / NP 241.
    Is`t a good idea?(ratio an so on,milage). Will it fit? (Th700case to engine, and all other things a have to keep in mind.
    My Chevy is Blazer -76 350 4 bolt main and the TH 700 / NP 241 comes from a blazer -89 350,(I will buy it from a junk yard)
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    is the 700r4 computer controled?
  3. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    Really good question! All i know is that it`s taken from a -89 Blazer
  4. gruveb
    gruveb Registered Member
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Nope.
  5. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    all it does is control the Lockdown on the 700R4 i swaped in a Th350 and rebuilt the NP241 the low range rocks on this with 2300 stall... /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
  6. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I don't here good things about the 700-r4, but you could be lucky
  8. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    The 700r4 is usually happier with a lower geared axle. I think you have this covered (5.99:1 Volvo portals). You should have a very useable 4th gear even with the 38.5's. Your crawl ratio will be much better:
    TH350+NP203+5.99Axle=29.95
    TH700r4+NP241+5.99Axle=49.49
    Make sure you use a LARGE tranny cooler and you should be just fine.
  9. Anthonviking
    May 25, 2003
    44
    Varnamo, SWEDEN
    THANKS EVERYBODY!!!
