th 350 ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Dec 11, 2001.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    When I was coming home tonight I went to go into the driveway and when I came up the little bump(gutter) and gave it some gas there was no going foward and when the rpms dropped it was in gear again (has done it when I was backing out to) could it just be an adjustment or ??? Thanks for the help in advance....
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Do you think the frame flexed when you entered the driveway? Could be your linkage was pulled into neutral by body/frame flex. May want to inpect body mounts. Also loosen linkage bolt at steering column to see if it shifts a bit. Then retighten. JT
