TH-400 2WD FIXED YOLK QUARRY
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RUSS84K5, Mar 28, 2003.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi,
    I have a TH-400 in my 2wd 77 pickup. It is a fixed yolk model. Dose anyone know if I can take the tail houseing off, cut off the threads and bolt up a t-case adaptor and 205?
    Russ
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    If it's the short tailhousing (should be), you won't even have to cut it. I used a 78. You will need the correct adapter and 205. Check this out and this, also
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  3. RUSS84K5
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi Brett,
    Thanks for the info. So do assume that it is a 32 spline, and the 205 needs the short female input?
    Thanks a ton
    Russ
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Hi,
    Russ
    Like he said, and by the way the 2wd th400 doesn't have threads at the end.
    The shaft is drille and tapped for a 3/8" bolt that holds the yoke on.
    I am putting a 208 on mine and it came from a 2wd truck.
  5. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    You are correct, sir. It is 32 spline and will work with the short input with the 400/205 adapter (pre-85, figure 8). Any other questions, just let me know.
