TH 400 help. Converting 2wd to 4wd.
Discussion in 'The Garage' started by 8_YOUR_H2, Oct 28, 2005.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I found a 2wd TH400 freshly rebuilt and ready to go that I am thinking about buying. The guy is telling me that all I need to do is un bolt the 2wd snout and it will fit up to a 205 or a 203, assuming the tcase was originally mated to a TH400. Does this sound right?
    **also....is it true that the TH 400 has no kickdown cable?
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    This will for sure work with a 205 with a figure "8" style adapter, however it will NOT work with a 203 or a later 205 with a round style adapter.
    Edit: no kickdown cable, the TH400 uses a push button style switch under the gas pedal.
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i changed my long shaft out for a short shaft, and it bolts right up to my 203
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I've got several TH400/?? set ups and all of them take different length tailshafts. If I remember the lengths are -
    TH400/205 (figure 8) = 4.5"
    TH400/205 (round) = 3.5"
    TH400/203 = 1.5"
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Decided to go with a TH350 after all....thanks any way folks!
