th-400 kickdown
Discussion in 'The Garage' started by slackjawsk5, Apr 4, 2006.
  1. slackjawsk5
    slackjawsk5 Registered Member
    Jan 29, 2006
    38
    berlin,wisconsin
    i posted earlier on the year specific board and was informed that my turbo 400 tranny doesn't have a detent cable and instead it is electrical kickdown via the gas pedal to switch is this true? and if so does anyone have pictures of this setup. i have been tring to resolve this problem and cant figure it out.
    when i floor it there is no kickdown
    thanks guys:doah: :dunno:
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have a th400 in my 90 and never hooked the kickdown up. I just shift it down manually when needed. I might eventually hook it up but I doubt it. Yes it is electronic. There are several kits available to make it work.
  4. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    i just got them now for ya.
  5. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    sweet is that the way a th-400 kicks down and does it matter that i have a b&m quickshifter
  6. sweetk30
    Nov 1, 2004
    25,544
    540
    thats the exact factory setup. the 3 bolts on your gas pedel piviot point come off and remove the stock plate and bolt this on and plug in the power wire to the fuse panel and run the orange to the tranny. bam its that simple. shifter dont mader as it runs off the gas pedel.
  7. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    sweet dont mean to be a pain in your rear but where does it hook up to the tranny im use to the cable style
  8. sweetk30
    Nov 1, 2004
    25,544
    540
    left side 1 flat spade plug. near rear just above pan rail:D
    anything else :confused: :D
  9. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    yeah the spade plug was standard on the tranny? and where can i get one of those?
  10. sweetk30
    Nov 1, 2004
    25,544
    540
    plug on wire or tranny end?
  11. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    where can i get one of those switches
  12. sweetk30
    Nov 1, 2004
    25,544
    540
  13. slackjawsk5
    Jan 29, 2006
    38
    berlin,wisconsin
    thanks alot sweet,i thought you might of wanted to get rid of your hahahaha
