th-400 kickdown...
Discussion in 'The Garage' started by broncoman6524, Dec 29, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ok ive always thought taht a th400 used vacuum to operate kickdown...apparently its an electric swith. Correct? And the place to plug the wiring is on the pass side of the tranny behind the dipstick (towards t-case) and its just 1prong sticking out?
    How do i wire up/rig something to make the tranny kickdown when the i mash the skinny pedal? If it matters its an 84 k5 350 and it WAS a 700 till it died:haha:
  2. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    the trucks that had the 400 orignaly had a switch the mounted to the gas pedal bracket . so just find a truck that had a 400 in it a get the switch
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The switch goes on the bracket that holds the gas pedal. One wire goes to a fused "Hot in run" power feed in the fuse panel. The other wire goes to the connector on the side of the trans.
    I got my switch from an old Jeep Wagoneer. The full size ones. They came with Turbo 400's in the early 70's.
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    ok, can i get this from like any vehicle that had a th400? i mean like malibus, chevelles, w.e. i find? lol and will a th350 one work too?
  5. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Well, 350's have a mechanical kickdown via cable.
    A switch is a switch is a switch; all you gotta do is run 12V to that terminal on the side of the tranny, and it'll engage the solenoid and do its thing.
    Warning: It will REALLY kick down ;)
    There are LOTS of TH400 equipped pickups out there in the junkyards, though.
    -- A
  6. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Has to be from a T400 ,T350 uses a cable.
    Here's a few pics of the stuff you need to look for.
    Kick down switch
    harness from tranny to firewall
    harness from switch to fuse panel & to firewall
  7. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    hey boss man? care to put those into just htmls not attachments?:( lol. and thanks guys!
  8. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I believe you will find it to be on the drivers side of the tranny not the passanger side. Almost across from the vacume module.
  9. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    gotcha...does it matter if the switch is on hte gas pedal or on the carb linkage? i was lookin on google and chevelles had then on the linkages and opend up when stomped. Or should i just stick to a truck/van/burb/k5 style kickdown...thanks
  10. 6.2puller
    Jul 8, 2004
    569
    New England
    Just an on off switch, should not matter where it is located as long as it functions as the throtle moves.
  11. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    10-4 im gonna try and go to the yards tue bc i htink theyre closed on mon. lol ill hopefully get what i need so i can get htis **** workin. lol
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Just mount a push type starter button on the floor, under the gas pedal.:D
