TH 400 output lenths.
Discussion in 'The Garage' started by 1-tonmudder, Mar 23, 2007.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I know the Th400's for a 203 have a different lenth out-put than the ones for a 205,but what about a 208.Can I take the 208 off and put my short input 205 on without any changes,or will I have to get a long 205 input and/or change the out-put before it will work.I bought a Burb with a rebuilt 400 and want to keep it and ditch the 208.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    IIRC the 203 and 205 400's had the same stick out length and the 208 was different. :confused:
  3. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Short input 205's use a different output shaft than the 208's.
  4. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    The 203 uses the shortest TH-400 output, late 205 (long inupt) uses a shorter output than the early 205 (short input). I think that the 208 and the late 205 take the same output TH-400.
    As for your question, no you can't use the 208 version TH-400 with the short input 205.
    Gus
