th-400 question
Discussion in 'The Garage' started by 85burbanator, Nov 19, 2005.
  1. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i just got another th-400 trans and it looks alittle different from my other one. one (the bastard child with a 10 spline output shaft) has a large bearing right were the adapter bolts up. the new one one has no such bearing and i can se some of the internals (speedo gear and some stuff along the bottom). the new one bolts to an np208 tcase and im wondering if that void is normal. nothing appeared to be broken inside the case. the new trans is out of an 88 or 89 chevy truck. is this trans busted or is it good to go?
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    The void is normal. :wink1:
    All of the 10 spline units I've seen have been from Jeeps. Check the bellhousing bolt pattern, it may be different from your GM version. :doah:
  3. 85burbanator
    Feb 10, 2003
    577
    lake orion, mi
    upon closer inspection i relized it is infact broken. MODS PLEASE DELETE
