th 400 questions
Discussion in 'The Garage' started by short sub, Jul 13, 2005.
  1. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    ive had my 400 in the burban now for a few months but finally took it down the road and i noticed that it shifts out of gear way before it should- even if i manually shift it. I try to make it build power higher in its range and the tranny shifts before it should IMO. any suggestions?? thanks Ryan
  2. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Did it originally come from behind a diesel? May need to recalibrate the governor. Summit sells kits to do this.
    http://store.summitracing.com/
    part # BMM-20248 $29.88
  3. llegos
    llegos Registered Member
    Jul 12, 2005
    17
    P-town, Khalifornia
    diesel is a possibility, what RPM is it shifting at?
  4. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    When youre building power while manuel shifting, do the lines on the road look like dots?
  5. short sub
    Jan 17, 2005
    98
    Sealy Texas
    while manually shifting it shifts at around 4800. i really appreciate the ideas but what yall are tellin me is that i need to swap this new th400 out for a built 700 right??? :wink1: well let me know why its shifting so low later Ryan
