TH 400 to NP205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Dec 11, 2003.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Hey guys I need to know some stuff first I have a TH 400 that has a 208 t case round adaptor on it I would like to put a 205 behind it I have 2 205s both from behing 4 speeds what do I need to change or get Thanks. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You could come and get these sliding windows out of my backyard! /forums/images/graemlins/thumb.gif
  3. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Not sure what the 208 has for an input shaft(spline count)
    but the manual trans 205's are 10 spline male and the output on the T-400 is 32 spline male.the matching 205 for the t-400 has a 32 spline female.then there's the adaptor plate issue,,the plates for the T400/205's are getting hard to find.I shelled out the money and purchased a military T-400/205 assembly from Boyce Equipment. I also have two manual 205's sitting in my garage both with 10 spline shafts that I can't use with the T-400.Call Advance Adaptors and they may have a kit to bolt the two together.
    hope this helps!!!
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Put the 205's you have aside or sell them and look for any 205 out of any 1 ton 4x4 from '85 to '91. You can use either 205 that was behind the 400 or 465 during those years but if you find one that was behind a 465, you need the 400-version adaptor.
    Its that simple: find the 1 ton K30 205 with the correct adaptor and it will bolt right up to your current 208-version 400. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hey if you wanna get rid of the 208 there was somebody looking for a 32 spline 208 in the wanted forum. Prolly make enough to buy a 205 /forums/images/graemlins/thumb.gif
    Here it is
  6. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I took a 10 spline 205 and had a machine shop bore out the input bearing hole in the housing. Then added the 32 spline female input shaft and larger bearing. Machining was $60 and input shaft was $125 IIRC. If you do this, buy the bearing first and take it with you to the machine shop for good fit.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, this would work on the '84 and older 400's and 205's. It would not work on the '85 and newer 205's because the input shaft sticks out longer than the '84 and older. /forums/images/graemlins/thinking.gif
