TH-700 from a 2wd
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jul 17, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Ok, i would really dig a TH-700 because of the improved gas milage. I may have access to one from a 2wd pickup(85 silverado) My question is, will this bolt in plave of the TH350 i have now in my 73 blazer. My t-case is an NP203. And i already know about the reliability issues of the 700 when put work.
    Check out my 73 K5 members.theglobe.com/xnoahx/73k5.htm
  2. borton
    borton Registered Member
    Jun 4, 2001
    14
    Salt Lake City
    yes it can be done, you'll have to change the output shaft of the tranny and then get an adaptor, advanced adaptors has everyting you need.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If you currently have a TH350 all you need is to put a 4wd output shaft in and use the same adaptor as the TH350. You will have to move the crossmember back and may need to shorten your rear driveshaft and lenghten the front depending on much travel you currently have.
    If you didn't build it yourself, how can you call it yours.......?
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    3rd that, change the output shaft/housing, get new adapter, modify driveshafts (mild lift can help the rear shaft fit without shortening I think).
    Also, try to avoid a 700r4 from before '86/'87, unless it's been rebuilt to newer specs. Supposedly, there were lots of bugs in the originals that didn't really get worked out until '86/'87.
    Good luck! Hang on to the 350!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    No it will not bolt in place of the th350. Sorry this is not a bolt on affair!
    Good luck
  6. Leadfoot
    Nov 28, 2000
    3,112
    Your original adaptor should work, if you use the correct output shaft on the 700. Considering you have to change it from the 2wd one anyway.
  7. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Word of caution before you go this route...check to see if the 700 has a six bolt dust cover (should look just like your TH 350, covers the torque convertor/flywheel). These were designed for 4 wheel drives. The other type (4 bolt) will work but are a little weaker and may crack.
