TH350 / 205 combo?!
Discussion in 'The Garage' started by Russell, Jun 7, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Hey guys!
    I was crawlin around underneith a mid 80's 4x4 this morning and noticed that the thing has a TH350 with a 205 bolted to it.... Is that even possible, or is it a TH400 that has the modulator on the back instead of the side like my 2wd TH400 had?
    If it is a 400 / 205 unit, I think I may be pulling a tranny soon ;)
  2. evo
    evo Registered Member
    Dec 11, 2002
    30
    oregon
    look at the tranny pan. th350 is square with one corner cut off at an angle, the 400 is odd shaped pan, with a bunch of curves in it. hope that helps
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    There are 350/205's out there...
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Very possible , slip yoke 205 and th350 was around .
  5. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I have 350/205 combo.
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    1st Gens (69-72) are commonly found with the TH350/NP205 combo....
    :usaflag:
  7. Russell
    Jun 23, 2000
    7,921
    331
    Now that I think of it, I don't recall seeing any sort of kickdown cable, and the wiring on that truck was a mess, so it may very well be a TH400 / 205 combo :)
  8. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    i also have a th350/205 combo in my 75 blazer
  9. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    I just swapped in a 205 behind my TH350. The Np203 and Np205 look similar from the rear if your not familiar with them. But if it does have a TH400, SNAG IT!
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Could be a swapped in combo.. Check the pan like evo said.
    Does the 205 have a slip yoke?
  11. diesel4me
    Jul 24, 2003
    17,537
    921
    Massachussetts
    Its a TH350...
    If the modulator is facing the rear, near the tail shaft,its a TH350 for sure..A TH400 has the modulator sticking out sideways on the front passenger side ,near the bell housing....I think GM used the TH350 until around 1981-82 when then 700R4 was introduced..lots of 69-79 trucks had the TH350/NP205 setup..after that the overdrive tranny came along..the 80's 4x4 TH350's are rare,but they did have some..:crazy:
  12. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    I have a 205 from a 350, it does have a slip yoke. 1980
