TH350&205 from 73 sub onto a Th400&208 86 pick-up crossmember?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k10sub, Mar 15, 2003.
  1. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Getting ready to put the motor, tranny, and t-case into the m1008. However, the m1008 came with a TH400&208 and we are putting a TH350&205 in. Will the TH350&205 bolt onto the m1008 tranny/t-case crossmember, or do we need to get a TH350/205 tranny/t-case crossmember?
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    YOu can use it. In fact, it might be better because the 208 crossmemeber has a front shaft dip in it..so more clearance for your front shaft. Use the right mounts for the crossmember though. I think they might have changed in 86 or so.
    Blake
