TH350 and 203 to 205 compatibility?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the beast, Mar 10, 2005.
  1. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    I've got to replace the transmission in the Beast. It currently has a th350 w/ a 205. I got a th350 out of my donor truck that was connected to a 203.
    Will this be a direct bolt up, or will I need to change things on the 203 tranny? :confused: :dunno:
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    203 and 205 same output shaft in tranny. go for it bolt it up.
  3. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    All th350's were 27 spline,
    SM465's were 10 spline, HOWEVER, 32 spline from 86ish and up
    TH400's were 32 spline, can be either short or long output shaft
    np205 had 2 front outputs, 10 spline and 30 spline..easiest way to tell..if thers a 1310 yoke, its a 10 spline.....if theres a flat flange, 30 spline...IIRC 77 ish and under was 10 spline, 77^ obviously 30 spline..
  4. the beast
    Oct 15, 2003
    535
    Providence, RI
    Thanks guys. My big concern was if the trannys were compatible.
    I'll be running just the 205 for a while until I get the big axles in and the plate for a doubler. :D
    This takes a major load off my mind. I need to get this truck back on the road.
