TH350 and TBI Q?
Discussion in 'The Garage' started by southernspeed, Apr 11, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Who has a TBI with a TH350?
    Which vaccum port on the throttle body did you use for the trans?? Or did you take it off of the manifold? Thanks :)
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Come on...don't be shy! Someone must have this set up!! :)
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont have that set up but I would use manifold vaccum. Most of the ports on the TB are for sensors. If the Vac modulator goes bad and leaks you wouldn't want to risk getting trans fluid in a map sensor or something.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Hmmm..good point! I wanted to use a port for ease and tidyness but I see what you're saying.
  5. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    it goes on the manifold in the back side of the tbi unit. not on the tbi. had this setup in my old dd truck worked good. then i missed my od and went to a 4l80 setup.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks, I've got a take off for that outlet so I'll stick it there. My DD has a 700r4 and I think I'm really going to miss the overdrive so I'm keeping an eye out for a 700. One may turn up one day! :)
  7. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If it wasn't for that small pond in the way you could have mine when I find a 400 :D
  8. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Hey...i got a little row boat!!!! :D
  9. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just put it in a big bottle and toss it in when the tide is going out.
