th350 and th400 and np205??
Discussion in 'The Garage' started by chevy_mud_84, Jun 26, 2005.
  1. chevy_mud_84
    chevy_mud_84 Registered Member
    Feb 28, 2005
    89
    Brockville, ON, Canada
    I have a th350 that has a np203 attached to it, and im swapping it for an np205. I already have the 205 sittin in the garage. But now my question is.....the truck that i took the 205 outta was an 1980 3/4ton chev, and i think it had a th350 in it as well, but then i got told that both the th350 and 400 are 3 speeds. Which i didnt know, i thaught only that 350 was. So is it true they are both 3 speeds cuz i never looked at the oil pan too see which one it was i just went by the number of gears it showed. So if it was a 400 and not a 350, will this 205 still bolt up to my 350 or no? I took the adapter, that was used on that truck aswell, so i have all the parts, but need to know whether it'll work or not. Thanks and sorry for the long question, im just tryin to get this all done and figured out before the next 4x4 comp. this summer.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    3 speed on automatics means "L, 2, 1" with 1 being the direct 1 to 1 ratio which you put in drive. If it were an overdrive auto, it would have read "1, 2, 3, OD" or something like that.
    A 205 behind the 350 or 400 will not interchange due to the input shaft variations. You can have a 350 equipped 205 machined to fit a 400 by boring the bearing hole a larger diameter and swapping in the correct input shaft, but you can't make a 400 equipped 205 fit a 350.
  3. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    If its for a 400, It wont bolt up to the 350 tranny. Different input shaft splines.
  4. icer97
    Jun 15, 2005
    116
    Missouri
    Beat me to it! :grin:
  5. chevy_mud_84
    Feb 28, 2005
    89
    Dammit!!! It better be off a 350. I guess i better go find that truck in the junk yard again. If it is from a 400 is it possible to buy and adapter plate? if so any ideas how much, and where?
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    I'm working out details with icer right now to buy his 400/205 combo. All I really need is the 205 for a Doubler project and the 400 for my K30 which blew holes and cracks in the bellhousing. I need a replacement housing for swapping my 400 internals over to the new housing.
    Now if you, me and Icer can come to terms here, I would be more than happy to let Icer and you work out a deal for the 400/205 adaptor from him providing he knock off the price from the 400/205 combo.
    Let me send him a PM. :deal: :waytogo:
  7. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    You dont have to go back to the yard and look at the truck. The differences between a TH400 NP205 and a TH350 NP205 are quite easy to identify. TH350 version NP205s will have a male 27 spline input and the adaptor would have came with a 27 spline coupler. If it is a TH400 version it will have a 32 spline female input gear. If you do accidently have the wrong version your not out of luck as the TH400 version is a fairly desirable case and im sure you could sell it on this board and re-coup more then enough to find the proper case.
    Jordan
    NorthwestFab
  8. icer97
    Jun 15, 2005
    116
    Missouri
    I have the adaptor, PM me and maybe us 3 could work out something. :grin:
  9. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    even easyer way to tell that no one told was th350/th700 use 4 bolt holes to tranny on adaptor. th400/4l80-e use 6 bolt holes to hole tranny to tcase adaptor. and also what northwestfab said on the spline count and setup.
  10. chevy_mud_84
    Feb 28, 2005
    89
    Yes!!!
    Sweet ok, im happy now!! So ya mine has the 4 bolts for the adapter and it has a 27 spline shaft, that means its for a th350?? if thats so, then im in luck.
    Thanks guys. you've just made my day.
