Th350 cooler lines question
Discussion in 'The Garage' started by TrcksR4ME, May 19, 2005.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    In the process of swapping out my tranny (turned into a much bigger ordeal than anticipated) I lost track of which like goes where on the tranny. Need to know which outlet is in and which is out on the tranny itself. TIA! :laugh:
  2. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    THANKS! :cool1:
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    why does it say 1/8" ?
    they are 5/16"
    so top one is not feed
    hum al;ways was told that top was feed
    and bottom was return
    interesting
  5. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I think you might be right, I felt the lines and the one that is suppose to be return according to TCI is hot, and the other one is cool(cooler than the other one).
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    was the transmission warm, not just the motor? if not, the coolant was heating the tranny fluid up, not cooling it.
    the bottom is feed and the top is return on the th400, th350 and the 700r4, they also all use the same 5/16" line.
  7. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    The line coming out of the radiator was cooler than the one from the external cooler. IIRC it should be the other way around right?
  8. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    1/8 refers to thread size and the line itself is 5/16.
