Th350 Guru's Help
Discussion in 'The Garage' started by CB77GMC, Mar 15, 2006.
  1. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    On a TH350 can the front pump seal be changed in truck ? .....Yes I know it will be small work space. Reason for asking is have old 350 out back and tried to pull front pump. It won't move any tricks ? Includes BFH :confused:
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    there are two holes in the pump that are threaded that you put a bolt with a t handle on and use it to pull the pump if you can't pop it right out hammer them a little bit and it will come out. Just look at your pump carefully and you will see which holes I am talking about :D
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    And when you do get it loose, watch out, its heavy.
