TH350 Hard shift questions
Discussion in 'The Garage' started by laketex, Jun 12, 2002.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Ok, I got my tranny rebuilt about 2 years ago, but didn't get it installed till feb of this year. I've run it about 30 miles and it shifts like crap. The only way it'll shift up is with my foot flat on the floor and the motor wound way out, then it does with a huge jerk. Downshifting is sporadic, sometimes it does right, sometimes it has to be done manually. Need to know what to do here. Fluid's fine, tranny's out of warranty. Do i need a new rebuild or is it something simple?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Sounds to me like your vacuum modulator isn't getting any vacuum. Is it hooked up? A friend of mine didn't have the metal line to run the vacuum to the modulator so he just ran hose all the way down. The hose colapsed and his transmission was acting the same way.
    Mike
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah check the vacuum line. It'll cause those things to happen.
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I would assume the vacuum line or modulator.
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yes, Sorry for the vagueness. I meant the vacuum line that connects from somewhere on the intake manifold that goes down to the back of the transmission to the vacuum modulator.
  6. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I think it is the Vacuum mod. or line is off.Had this happen on the wifes Sub.
  7. laketex
    6,220
    North Texas
    Thanks to all of yall. It was indeed the vaccum line. All split out and not doing its job properly. I have a metal hard line and a little bit of hose at each end to connect the two. The hose was messed up so I replaced each with a piece of fuel line. works and shifts great now. Thanks again to all of yall. Saved me a TON of work.
    Bryan
