th350 leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dheavychevy38, Aug 30, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i have a th350 that is leaking around the kick down cable mount in the trans what to do??????? /forums/images/graemlins/k5.gif
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    pull out the kick down cable and replace it or minimum replace the rubber o ring that seals it and put a dab of silicon around the base also before ya put it back in the tranny
    do the work your self and save the money take 25.00 of the $$ ya saved and send it to steve for your member ship :-) think of it as a investment that just keeps on giving ya great returns - v.p.d. ( value per doller )
    good luck
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I'd agree... Be careful not to tighten it too much otherwise you'll hear a crack and it will still leak. /forums/images/graemlins/grin.gif
    Also check the lines that go into the tranny right above that... and the dipstick tube.. Wipe it all down real good and try to pinpoint where your leak is coming from.
  4. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    Yes, a cracked KD cable housing is a common cause for leaks
    The dipstick mounting bracket, that goes to the bellhousing bolt, is "spot-welded" to the very thin dipstick tube.. they frequently crack from taking the measuring stick in and out.. it leaks down and blows back the edge of the case looking like it is comming from the KD cable..watch for that... /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
