TH350 LEAKS INTO NP205...WHY?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 383STROKERINAK5, Jan 20, 2003.
  1. 383STROKERINAK5
    383STROKERINAK5 Registered Member
    Oct 13, 2002
    17
    CLOVIS,CA,USA
    THIS DAMN THING WON'T STOP LEAKING. I HAVE HAD THE SEALS REPLACED TWICE,ONCE WITH AFTERMARKET SEALS AND ONCE WITH FACTORY STUFF. IS THE DARN THING WARPED OR WHAT? AT TIMES IT WILL LEAK SO BAD THAT WHEN I LET IT SIT FOR A FEW DAYS THE FLUID WILL RUN DOWN THE DRIVESHAFT AND PUDDLE UP UNDERNEATH THE REAR END. ANY SUGGESTION ON WHAT I SHOULD DO? P /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gifHIL
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Your seals could be getting damaged while installing the t-case. That is what happened to my 1979 K10 when the previous owner replaced the seal at the back of the adapter. Also check the shaft for a groove where the seal contacts the shaft.
  3. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    There might be a plug inside the t-case input shaft that is not sealing properly. Check there!
