TH350 Lock Up Converter Switch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RiceDaddy, Aug 12, 2003.
  1. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    This switch is leaking fluid around it...bad.
    How do I replace it? I assume there is a gasket or o-ring that seals it in there so that's really what I need to fix.
  2. dyeager535
    26,979
    Probably retained the same way the TH700 TCC plug is. Of course, I have no idea how that is. /forums/images/graemlins/frown.gif
    I would imagine it uses an o-ring, if it does, I'd deal with a hydraulic hose place, as GM is typically insane on o-ring prices. Either that or talk to a local tranny place.
  3. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    I went to Napa and we looked in "the book" and found a part number for an O-ring. I bought it (61 cents). I'm guessing that I have to drop the pan and get at it from underneath. It doesn't seem to want to wiggle out from up top. Any thoughts?
  4. dyeager535
    26,979
    The 200-4R uses a similar setup,but for the life of me, can't recall how it comes out...I want to think that it uses "fingers" on the inside of the case, so you push it into the case and it locks in place. But I'm not sure.
    If someone can chime in with how the 700R4 wiring plug is retained, it will hopefully be the same as what you will deal with. I'd be really surprised if it was retained from the outside.
