th350/np205 sleeve
Discussion in 'The Garage' started by arq, Jun 10, 2003.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I hear that there are two versions of the th350/np205 adapter. does the sleeve change between these and are they interchangable??? can anyone identify this one.
    [​IMG] [​IMG] [​IMG]
    larger image
    thanks,
    ARQ.
  2. Larry
    Larry 1/2 ton status Premium Member GMOTM Winner Author
    Jul 18, 2000
    1,096
    216
    A windy corner of a dirty street: Pueblo West, CO
    I am not sure what that thing is but it looks nothing like the one used in my 72’ K5 Blazer with a TH350/205 nor the sleeve behind my 78’ K10 with a TH350/NP203 when it was still an automatic.
    By process of elimination it may be safe to say it is newer than 72’, older than 81’ since the auto trans sleeves were not used in the 81 or newer aluminum 208’s & 241’s, has too many splines to be a SM465 manual variant. Dang...not sure what the heck that is from.
    I guarantee someone here will know.
  3. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,007
    195
    Santa Maria, CA
    I have collected quite a few th350/205s made from 1969 to 1973. The sleeve you have is a pre 1973 that is supported by a big bearing. The later model sleeve does not have the step where the bearing mounts and has a snap ring inside the middle the sleeve to keep the sleeve from walking back and forth. I have never done it, but you could put a later model sleeve in a earlier adapter if you leave the bearing out. But I think you could get new sleeves (both early models and late models) at ORD.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    thanks JD... /forums/images/graemlins/smile.gif
    ARQ.
