? Th350..&..np241
Discussion in 'The Garage' started by blazinjimmy, Nov 27, 2006.
  1. blazinjimmy
    blazinjimmy Registered Member
    Aug 28, 2003
    53
    I have a 74/89 jimmy...350 transmission, 203 transfer case. What would be involved in throwing a 241 transfer case into it? [I have a 241 sitting here].
    Thank u.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Try and redrill the adapter for the round 241 pattern?
    Any other stock TH350 or TH700 adapter is going to be longer and the splines won't meet :(
  3. blazinjimmy
    Aug 28, 2003
    53
    Adapter
    Is there an adapter plate for a th350, and a 241 transfr?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The adapter from a 700R4/241 will work but the stick out length on the tranny won't be correct. You will need a special output shaft for the TH350 to run a NP241 with the 700R4 adapter.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    The TH350/NP208 adapter would work, but it needs the matching length shaft in the TH350.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The 208 and 241 use the same adapter.
  7. blazinjimmy
    Aug 28, 2003
    53
    So the TH350/NP208 would work?......and what do u mean 'matching length' shaft?...matching to what? [sorry if this is a dumb Question, but I know nothing about this]
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they're speaking of the output shaft on the trans. although the 203 and the 208 (TH350 version) should both be 27 spline. :dunno:
    i dont see why you couldnt round up a 350/208 adapter, and bolt it all together, providing your 241 is a 27 spline.
  9. u2slow
    May 9, 2001
    2,217
    BC Canada
    The TH350 used with the NP208 had a longer output shaft.
    The super-short TH350 shaft was only used with the 203 and 205 t-cases.
  10. blazinjimmy
    Aug 28, 2003
    53
    Thanks for the info guys....I was hoping it would be an easy swap, oh well.
  11. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    3/4 inche stickout on 203, 205 versio 3 " stick out on 208 version
  12. dessellier93
    dessellier93 Registered Member
    Jan 13, 2011
    14
    vulcan MI
    th350 to np241
    what do i need to change for my np241 to bolt to my th350??
  13. dessellier93
    Jan 13, 2011
    14
    vulcan MI
    what shaft would i need to change to get my np241 to bolt up to th350
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You need a shaft for the th350, the same one from a 81 only when they offered the 208 behind the th350. And you will need the right adapter, which I happen to have.
    why would you want to though?
  15. dessellier93
    Jan 13, 2011
    14
    vulcan MI
    okay but theres nothing i can change on transfercase? and if i got a 208 would it still work out? going in a 93chev1500
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The 208 and 241 will mount on the same setup.
    My question is why the th350?
    You can just find a 700R4 that will bolt right up, and for a 93 it must already have that.:dunno:
  17. dessellier93
    Jan 13, 2011
    14
    vulcan MI
    the 350 was only thing had available at time and just going to use it also this truck used to be a 5spd so theres no wiring available and it had a turbo 400 in it before this
  18. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    The Th400 will be easier to adapt since it was offered for so many years with the 208 and the 241, you will need the 32spline input for that tcase though.
    So what parts do you have available now?
    th350 what else?
  19. dessellier93
    Jan 13, 2011
    14
    vulcan MI
    the th350 adapter hopefully right one and np241
  20. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Guessing the 241 is driver side since it's what you need for a 93 unless you are going solid axle.
    How long is your th350 output shaft?
    and do you have an adapter from a 700R4?
