TH350 output shaft
Discussion in 'Parts & Trucks Wanted' started by joefl, Mar 26, 2005.
  1. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    TH350 output shaft that will work for NP208
  2. joefl
    Aug 18, 2004
    153
    Marianna, Florida
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I think any 4x4 TH350 output shaft will work for you. They didn't change the length of the output shaft on the TH350 like they did with the TH400.
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I disagree.
    There were 2 versions of the 4X4 T350 output shaft:
    A short version with a stickout of about 7/8" for the NP203 and NP205.
    A longer version used with the NP208/NP241- between 2" to 2 1/2" stickout.
  5. joefl
    Aug 18, 2004
    153
    Marianna, Florida
    4x4 output shaft want work. from what i have read you got to use a 2x4 th350,
  6. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    The 2WD version output shaft may work with the NP208 but why bother??
    GM offered the NP208 behind the T350 in the early eighties.
    Surely someone on the board here has a 208 version T350...
