th350 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Oct 5, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    I asked this question ealier but did not get much feedback. so I'll try again. Just installed rebuit th350. Can't remember which hose line goes on top and which on bottom. Two lines Between the radiator and tranny. Lines are identical in length and form. I am assuming the top conn. on tranny goes the the top conn. on radiator and the bottom conn. goes to the bottom conn. Anyone who has a th350. Could you possible look at your lines and confirm this for me. I.ve been told it dosen't matter, but I am skeptical of that answer.
  2. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Top to top, bottom to bottom. It really doesn't matter. The hook up at the radiator is bi-directional and will not hurt anything if it is reversed. If you were able to look inside your radiator the right side tank has a small radiator in it which circulates the transmission fluid. It won't hurt a thing if these lines are crossed. Make sure that the lines are not kinked, clogged or nicked. Other than that hook them up. Mine go top to top and bottom to bottom.
  3. James
    Jun 22, 2000
    179
    Castaic, Ca
    Perfect, I got the same answer from sosamantax. I appreciate it.
    James
