TH350 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suzukirider85, Dec 20, 2002.
  1. Suzukirider85
    Suzukirider85 Registered Member
    Sep 11, 2002
    6
    i have a 1975 K-10 pickup w/a 350 engine and a th350 tranny. what is the recomended tranny fluid to use? Typr F or dexron/merkron /forums/images/graemlins/truck.gif
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    dexron is what would be recommended, type F was used in ford automatic transmissions many years ago.
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    dexron/merkron
    Hmmm, I wouldnt put that in there either. How about Dexron III/Mercon.
    Just messin with ya. Fill out your profile so we can know a little more about you.
  4. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Type F CAN be used in a GM tranny. I know of only 1 person doing it and I have talked to a tranny guy about it. Type F has no friction modifiers like Dexron does. Basicly it makes the shifts more snappy and there is less slippage. IIRC. The tranny guy told me that the B&amp;M Trik Shift is basicly Type F fluid.
    I am considering using Type F when I do the next fluid and filter change. But I am gonna talk to the tranny guy again before doing it. /forums/images/graemlins/crazy.gif
    Id recommend talking to a tranny tech w/ performance experience before trying it tho.
  5. 74Chev
    74Chev 1/2 ton status
    Sep 19, 2002
    102
    Oregon
    Pure insanity is right type F can be used in an older GM tranny. Type F is a thicker tranny fluid than Dexron III. DexronIII/Mercon is 5-20 weight fluid where type F is I believe 10-30. It performs very poorly at extremely low temperatures and could fail at high temp towing situations, due to its lack of additives, (anti-wear agents, anti foamers, etc.) The type F is a very basic fluid compared to the modern ATF's and will not provide the best protection for your tranny. It will provide firmer shifts, but at the trade off of increased protection given by Dex III. I would not recommend using type F in your daily driver. I use a relatively new fluid called Mercon V. It is the newest spec. used by Ford, introduced about 1998 in certain models and exceeds approval specs. for Dex III and Mercon. It is a higher performance fluid and has increased shear strength, excellent low and high temp operation, resistance to breakdown, provides longer drain intervals, and can stand up to extreme operating conditions. If you do decide to use Mercon V (five) fluid have the trans flushed by a lube shop that carries the Mercon V fluid, as it will be very hard to find in stores. By the way this stuff is about 3-4 dollars per quart but cheaper than a blown tranny. If you don't want to spend that much the newest Dex III/Mercon is a good spec. and should provide great pumpability and protection in most situations. The Chevron brand Dexron III/Mercon fluid is excellent and is the preferred fluid for many industrial and heavy duty applications. It is definitely better than most of the others on the market, especially the cheapies.
  6. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    type f type f type f all the way!!!!!!!!!!!!!!
  7. Suzukirider85
    Sep 11, 2002
    6
    thanks all, i work for the local ford dealership so getting fluid for it and a flush isn't that hard. /forums/images/graemlins/truck.gif
  8. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    I believe that Mercon V is synthetic, atleast the kind that Autozone carries is.
  9. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    I have the same truck and I'm pretty sure the tranny is original. I just emptied it and filled it with the new Dexron III stuff and it is working fine.
    I'm going completely through my truck, so if you have any other specific questions particular to the 75, let me know.
    Good luck.
  10. Suzukirider85
    Sep 11, 2002
    6
    How about the transfer case. used the same stuff?
  11. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Nope! If it is an NP203 like mine, you want to put regular motor oil in the transfer case. I think my book said 20-40w or so. I don't think it really matters as long as you don't put gear oil or transmission fluid in there.
    If you nave a different Transfer case, you will need something different. Fill out your profile and you will get more direct answers. In any case, good luck and Merry Christmas. I'm off to see Santa.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    10W-30 is actually the spec for a 203, but I agree with you it doesn't really matter. Just make sure it's motor oil you're putting in there.
