TH350 rebuild
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelnut46, Jul 15, 2002.
  1. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    I realize that costs differ from shop to shop and region to region, but what would I expect to pay for a trans rebuild? I would like the truck to be built mostly for everyday driving and towing. It has the NP203 transfer case.
  2. wheelnut46
    Nov 27, 2001
    122
    Rhode Island
    Back to the top.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You can buy a rebuild for about $500 with core. To get it rebuilt will probably run up near there. The rebuild kit is about $100 and can be done by an intermediate mechanic. If you've ever rebuilt a stick, automatics are a snap (everone seems to think otherwise though).
  4. Grim-Reaper
    7,385
    Atlanta
    I would put a RV or towing kit in it. It will bring up the line pressure so it will have better clamping force for heavy loads. It's not extreme like a Shift kit. A shift kit will be super hard and quik shift. THis is a happy medium between that and a soft stock shift.
    If you pull the tranny yourself most small non chain tranny shops will rebuild it for between $300-400. Parts total to rebuild one including new Steels, Clutches and seals with a flush kit and rebuilt converter is in the $125 range. Not really hard to rebuild one. Pretty straight forward. One thing that sometimes happens is the splines on the stator shaft (the shaft the converter rides on) will start stripping off. It's part of the pump assembly and you will have to get a rebuilt pump to fix the problem. I got a rebuilt pump, used sprag and forward drive drum from local tranny place for $75.
    Previous owner liked doing neutraldrops and blew the sprag and trashed the drum.
    I bought my parts from a Place called Delta automotive. They sell to tranny shops but will set up an account for and individual. You can also get stuff like chains for your 203 from them. Don't forget to flush the cooler. If you don't have a AUX cooler get one. 9 out of 10 tranny failures are heat related.
