TH350 replacement 79' Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlueKnight, May 1, 2000.
  1. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    TH350 replacement 79\' Blazer
    A friend of mine in a group I belong to wants to sell me two really nice condition TH350's. one short shaft and one long shaft. I have a TH350 transmission already but was wondering if I went with a short shaft would this solve some of my driveline issues being so short and steep of angles or do I already have a short shaft installed?
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    http://79blueknight.homepage.com
  2. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    Re: TH350 replacement 79\' Blazer
    Isn´t your current th350 of the "married" type (t-case bolted directly to the tranny)?
    Andreas
    406cui of pure sh*t[​IMG]
  3. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I just had my TH-350 rebuilt. I like it real well, although I'm not running anywhere near 600 hp!
    Blazin' in Flagstaff
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    I believe that short-shaft and long-shaft refers to two wheel drive applications. As far as I know, all TH-350 for 4WD's are the same length. Anyone want to confirm this?
  5. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    mine is married to the 203, the 203 has it's own tailshaft.
    '77 K5
    <font color=red>mudfanatic</font color=red>[​IMG]
  6. Grim-Reaper
    7,385
    Atlanta
    The actual case up to where the tail shaft housing is the same. The short/Long does refure to how long the tail shaft housing and and shaft are. This is not a 4x4 TH350 but you can make it one if you choose. The best TH350 is the 77-80'(80 was the TH350c that had a lock up converter) that came in 4x4 trucks. They had a thicker bellhousing that would accept the heavy duty belhousing cover. This cover has a provision for braces that bolt to the motor mounts. You can make these tranny's work by swaping the output shaft to the 4x4 model shaft but this does require that the whole tranny be taken apart to get to that last shaft.
    FYI you can rebuild a TH350 for about $125 in parts. that would include new clutches, steels, seals and a rebuilt converter. I have rebuilt mine and it really wasn't that hard. Just took some creativity with tools.
    Diging it in the dirt with my K5's
    Grim-Reaper
