TH350 return line
Discussion in 'The Garage' started by ssls6, Jan 30, 2005.
  1. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    Which two cooler lines on a TH350 is the return line? I want to install an addition cooler and need to tap into the return line so I cool after the radiator cools.
    Thanks,
    RLK
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Upper is return on both tranny/radiator.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    so tops together and bottoms together then ?
  4. AkMudr
    Dec 30, 2004
    917
    Alaska
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what if you go and add a stock late 70s chevy truck aluminum tranny cooler in front of radiator just like factory did and all that,
    how do you route lines then with th350 ?
    thanks
  6. AkMudr
    Dec 30, 2004
    917
    Alaska
    Always mount it on the return side whre the temps are highest for maximum cooling effect.
